Can you provide a link to download image for Rasperry Pi 2 because the one you provide go to a chinese cloud and we need an account to be able to download the file.Thank you
userHead JaneYu 2016-04-29 21:26:11 9 Views24 Replies
Thank you
2021-08-20 03:37:17
Is it compatible with Jetson Nano, L4T?
Yes, you can use it as a display for most embedded development board on the current market
2021-09-30 09:41:25
2019-08-27 03:48:34
Just purchased this screen and cannot find any of the drivers to get it running. In the user manual there are some download links but they seem to be broken? Its connected to a RPi 3 Model B+.
Hey Phillip,
Sorry for the issue. You can find the related drivers on the following github: https://github.com/robopeak... . We will try to fix the links, but it is a third party supplier.
2019-08-27 09:48:46
2018-05-31 01:23:16
What pin spacing is the JST connector on this board? For my project it would be nice if I could use that instead of the micro USB so I want to buy a cable, but there's a lot of similar looking connectors.
The pin space is 1.25mm, you can searching the connector by this data and its shape.
2018-05-31 14:17:40
2018-05-31 01:00:52
If you are comfortable building an out-of-tree Linux kernel module, I see no reason why this won't work with a Pi Zero. I have it working (including the touch sensor) with a Sierra Wireless WP7702 module, which is most definitely not officially supported by RoboPeak. Unfortunately, there are a few compiler warnings that may need to be fixed. I have them (one from me and two I merged from someone else) in a GitHub repo:
https://github.com/fgodfrey...
2018-02-28 11:16:23
Did you follow the Basic Usage part in the user manual?
2018-01-21 22:39:37
Hello. Can you tell me exact working display area size in mm? Datasheet contains only module size.
2017-09-26 21:55:32
What is the temperature range of this product ?
Thanks !
It works in normal environment temperature, do you plan to use it in some specific environment?
2017-09-27 10:36:41
2017-02-10 20:34:08
I am trying to use this display via ffmpeg as fbdev. But I have got error in the following lines. Could you help me?
I am working on ubuntu 14.04.
"[fbdev @ 0x24b09c0] Framebuffer pixel format not supported.
Could not write header for output file #0 (incorrect codec parameters ?): Invalid argumentStream mapping:"
thanks.
2017-01-18 00:02:20
Hi david, might be possible to have some help whit this? im working whit a pi3 and a c code. i need to put an image in the FB, and refresh with a button. do you have some example code to work with in this screen? greetings!
2016-12-05 15:30:20
Hello
We have plan to use this display in our machines but we want to know how long this display will available in the market ?
2016-10-14 14:21:26
I'm sorry no. But would you mind sharing why you need such a mini screen? 2.8 is too small for windows operation system
Hi, I also would like to use this monitor for Windows 10, as we are doing research and we have a special need for it.
Any way to get this working on a Windows 10 machine please
2020-03-30 16:01:36
2016-09-09 12:19:03
Chip? It is compatible with Raspberry Pi B, B+ only.
2016-07-21 12:05:07
Hi, I'm afraid it doesn't. there is no ROM for Pi zero
2016-06-26 22:40:38
Cute tiny display, but I cannot get it to work. I've tried over and over without success.
Which RPi are you using now? This screen doesn't support the last RPi 3. You can check the ROM for the compatible device.
2016-06-28 15:53:27
