Is there any way to control this AWESOME little robot with ANDROID devices?
userHead JaneYu 2016-05-02 10:25:50 9 Views8 Replies
2017-11-07 17:54:11
Do you mean when you press "up" of the joystick, the robot only move a short distance? As I know, with the BLE control code, GoBle should control the robot continuously.
2017-10-18 02:58:29
hi there, I have the basiuc kit and working well, i just decide to implement it with a ultrasonic sensor and a servo, any chance to have the schematics and code for those ones with the Arduino Uno shield rather than the Romeo?
2016-11-16 14:28:57
Hi , I also trying to work with 5xAA batteries, I was trying to run the basic program with terminal control, it seems to work OK without the motors, but when the main board is powered the program behaves in a weird way, The working motors time is random and is never a full second as programmed by the delay. can anyone approve that this is indeed not possible? and that using other battery will solve the problem
2016-09-09 14:07:55
Hi, what's your power supply? generally, recommend a lipo battery, AA battery is not too powerful
I was using the 5AA batteries and a 9v. I think your right that a lipo battery is required.
2016-09-11 07:05:50
2016-05-29 20:18:23
Can this be programmed? I mean, does it include the Arduino?
Yes, this kit include the Romeo BLE——arduino with Bluetooth and motor driver. You can program it as an ordinary Arduino
2016-05-30 21:20:57
2016-05-05 09:33:58
alright thanks for your help I'll try controlling it with a blutooth controller maybe that'll work
