Please be noted: the servo blade is not fittable with the socket, you have to use a knife to cut the blade to install it...
userHead JaneYu 2016-05-30 17:32:29 7 Views2 Replies
2019-02-23 08:13:29
Can you identify a few specific servo models that fit this p/t the best? I have a couple, but the alignment of the tilt servo hinge is not perfect with some servos, and the length of the drive gear extension from the servo ** is an issue with some other servos. Thanks.
the kit is compatibility with a series of SG90 or MG90, we recommend using both...
2019-02-25 18:14:16
