I saw this link for the bma220.h document: http://iotdk.intel.com/docs...I want to configure the sensor for standalone config of the thresholds to send signal out to its INT pin.An...
JaneYu 2016-07-24 11:36:14 7 Views2 Replies I saw this link for the bma220.h document: http://iotdk.intel.com/docs...
And as of now, I can't download a single zip file with the bma220.h and all its external lib dependencies.
I'm also looking for a code sample to do the threshold config.
This is Intel iot development kit, it is prepared for the MRAA library under eclipse. For Arduino, you can use our Arduino library directly. Please check our wiki page http://www.dfrobot.com/wiki...
JaneYu The wiki website uses the wire.h library... http://www.dfrobot.com/wiki...
Do you have the bma200.h library for arduino?
Or do you have sample code to config the internal parameters to trigger sending 1/0 to the INT pin of bma220.
