Hi, when you state "do not stall for extended periods of time" what do you mean by extended periods? I'm planning a device that will get used maybe 6-10 times a day, 2 days a week...
JaneYu 2016-07-28 18:28:12 5 Views4 Replies Hi, when you state "do not stall for extended periods of time" what do you mean by extended periods? I'm planning a device that will get used maybe 6-10 times a day, 2 days a week.
2022-02-04 01:33:22
JaneYu
will (4) Turbo Metal Gear Worm Motor (6V 40RPM 10kg/cm) work with the Quad DC Motor Driver Shield for Arduino without damage to the motor driver?
JaneYu 2017-05-30 18:40:52
JaneYu
Hi DFRobot,
Do you have a motor like this that could withstand 1,2 Nm on the output shaft?
Thanks in advance!
BR,
David
JaneYu 2016-12-21 03:11:03
JaneYu
Hi DFROBOT team,
I am interested in this motor and I would like to know if you can deliver it in Algeria.
How much does it cost and how long does it take?
Thank you !
JaneYu
