Does Lattepanda support window 7 professional?
JaneYu 2016-08-04 08:26:23 6 Views13 Replies Does Lattepanda support window 7 professional?
This is pretty amazing. Too good to be true actually:
"Supports 100Mbps Ethernet"
What is the big obstacle with putting a Gigabit NIC in there?
JaneYu I have several questions
1. I have 2 computers. Both with Windows 10. Can I use key from one of them?
2. There are "20 GPIOs from Arduino Leonardo". Does it mean that can I use it like orginal Arduino Leonardo also? (If yes, can I use both Windows 10 and Arduino in the same time?)
3. How much wattage uses this device?
(Sorry for my English)
JaneYu Seems to take upto 2.4A at 5V which equates to 12W maximum, it may use less real world.
There is basically an arduino leonardo built in on the circuit board. It appears to windows as a separate device, its the same as if it didnt have an arduino built in and you plugged one into the USB port instead.
1) no you can not
2) yes you can run both in parallel
3) Check this video: https://www.youtube.com/wat...
Please notice that LattePanda only provide the Win10 system.and driver. You can install win7 on it,but there might be a device incompatible issue.
JaneYu DF shall give the tracking number by email .Please check the mailbox you leaved in DFstore
JaneYu Here's is Getting-started Doc of LattePanda.Hope you will enjoy it. http://www.lattepanda.com/d... Hope you will enjoy it.
JaneYu the version that costs 79$ has windows pre installed or i must install windows by my self ?
thanks
JaneYu Is the USB3.0 port on this shielded? Since it's fairly close to the wireless chipset I'm a little concerned about 2.4GHz interference with active data transfers over the USB3 port. Have you guys tested this and seen any issues?
JaneYu Is there an option to automatically boot once power is applied to the board?
JaneYu Please check this out.The LattePanda team publish the "Auto-start bios update" in their Github
https://github.com/LattePan...
I live in Pennsylvania in the United States. Normally mail from China takes me 2+ weeks. My lattepanda arrived in less than 3 full days
JaneYu
