HI, I am testing this sensor and keep receiving CHECK_SUM_ERROR. Can i have the solution to solve it?
JaneYu 2016-08-04 11:44:49 15 Views11 Replies HI, I am testing this sensor and keep receiving CHECK_SUM_ERROR.
I bought this sensor but it doesn't work. the error is "DHT 11 sensor not found, check wiring"
I couldn't login in forum i think your website has a problem
I explian my problem in stackoverflow
JaneYu Did you use the sample code in the library? I test one here and it works well.
JaneYu I used sample code but didn't work.
Other DHT11 works well in same code.
I am having the same problem, check-sum-error. It is using 5volt supply? Is there a problem with the sample code?
JaneYu Do you use the library from the wiki?
Hello, can you please explain how to connect it to a rasbery pi 3?
As i have searched through internet usually the 3 pins are separated, the connector in this case has the 3 pins connected together
JaneYu Comme ce capteur peut fonctionner à 3.3V qui le rendent compatible avec Raspberry Pi , intel edison , joule et curies.
As this sensor can work at 3.3V which make it compatible with Raspberry Pi , intel edison , joule and curie
5V or 3,3V???????
JaneYu Hi, It is better to post your question and problem on the forum, and some connection photo will be very helpful.
.jpg)
