can it support 64-bit OS, can you run Windows 7 instead of Windows 10
JaneYu 2016-10-01 07:14:57 6 Views60 Replies can it support 64-bit OS, can you run Windows 7 instead of Windows 10
Yes it support Ubuntu, we had test the Ubuntu 16.04LTS on this board.
You could refer to this doc:
http://docs.lattepanda.com/...
JaneYu Hi, is there any knowledge that can be disclosed on if and when LattePanda V1 will be discontinued?
JaneYu We haven't heard anything about the discontinuation just yet.
May be you can ask the lattepanda techsupport:
[email protected]
If you check out our Wiki, we provide a variety of system images for LP installation. Your own system may cause emmc corruption, memory is not enough, you can choose external hard disk, etc. We also have a brand new product, 3delta, which is much smoother to use than V1.
JaneYu I see several differen th listings for the specs so pardon my ignorance, what are the best specs to use to use when buying a replacement powder supply. I think I lost mine?
JaneYu Does Linux work well on this SBC? Any documentation on that? Thanks
JaneYu @dfrobot:disqus Is it possible to write a program in visual studio and access the inputs/outputs of the arduino directly from windows?
JaneYu Hello, is there any way to connect a full sized video card to the latte panda?
JaneYu Hello, I am interested in the board, I would like to know if there is a possibility that I have already installed Windows 7 instead of Windows 10?
JaneYu Hi, The Lattepanda's Github presents 1.2 version as the last upgrade.
Can you confirm that you will ship this version for the 2BG/32GB unactived configuration ?
On the sticker it should be written S70CR200 as show like this link https://github.com/LattePan...
Thanks !
JaneYu Hi, i will have a problem from Microsoft if i sell this latte panda to a costumer? meaning it is not activated
JaneYu Hi. I got a project that ı want to go on but ı cant use 7"inch screen. it requires 4-5" inch screen. There are 25 pin mipi-dsi 4-5" screens on the market, but only 7"+ inch screens with 30 pins on the market. ı got the pinout diagrams of both 25 pin screens and the boards. can ı use it or if ı make right connections to boards connection, can ı use the screen? t https://uploads.disquscdn.c... here is an example
JaneYu Can ı use 25 pin mipi dsi screen on board?
JaneYu Here is the connecting interface, and it is mipi dsi screen https://uploads.disquscdn.c...
I bought this one a year ago and I almost did not use it (twice on a month maybe), only for watch videos on my TV.
Suddently, the LP is shut downed and it never turn on again, only the blue led blinks for ever.
I have the transparent case and the power supply and the usb cable are from DFRobot.
This is the video:
https://www.youtube.com/wat...
I don't recommend LattePanda, the support is weak and the LP is so fragile, I had it within case and I almost didn't use it and suddently it burned, baaaad!!!
Email response:
I guess the motherboard
or the power manager
damaged
,there is no good way to repair it.
I have checked the order, and you are out of the warranty, so we can not do the RMA for you.
Sorry for your inconvenience.
A greeting!
Best Regards
LattePanda Tech Support
LattePanda 技术支持
Room 615,Y1 Bldg,112,liangxiu Rd, SHANGHAI, CHINA
中国上海市浦东新区亮秀路112号Y1座615室
JaneYu Hi,
What did you do before your LP shut down, it is possible that your LP was shorted somewhere resulted in this.
Because it is out of warranty, we can't give you a replacement, please understand
