Is there mount available to mount the case to back of a monitor?
JaneYu 2016-09-30 19:05:30 5 Views6 Replies Is there mount available to mount the case to back of a monitor?
does it come with a cooling fan? which cooling fan should i get with this?
JaneYu This product does not contain a cooling fan, the fan link is as follows: https://www.dfrobot.com/product-1520.html
No, the size of Alpha is different from the first version, you can not use it.
JaneYu It says that the case comes with instructions. No, it doesn't. It comes with an exploded diagram that seems to be numbering things in the order you're supposed to assemble them. Kind of. Also, you cannot read it, it's too small. You'll have to go and look at it in the exploded view on the computer. At least I did. There also seems to be a lack of info on how to mount the fan to work with the case.
In the interest of your sanity, if you aren't a woman with small hands or a small child, you will need one to help you assemble this case. Note that you'll also have to attach the WIFI plug first, too. (The aforementioned woman or small child will be helpful here, too.)
I used a rubber band to keep the sides in place till everything was locked together. Until the last piece is clicked, it won't.
JaneYu the fan will only work with the plastic case they need to redesign the plywood one so it have the same function and somewhere to slot the wire's without it binding in the case its a precision bit of kit that deserve a proper fit and a plastic plate stand is ideal for standing the screen on anyway im designing a tv stand out of the box simple like
HI, I received the acrylic case and it looks great. Do I use glue to assemble the pieces together?
JaneYu
