can you please give me datasheet of this motor?
JaneYu 2016-09-29 19:02:52 10 Views6 Replies can you please give me datasheet of this motor?
1) I would like to ask the information for the encoder. How can I sample the information of the encoder. the example in data sheet seems like C language. How can I sample it by python language or matlab/simulink.
2) Which pin on Raspberri Pi should I connect to these to 2 encoders
JaneYu You can use Python and the RPi.GPIO library to set up and handle interrupts on the Raspberry Pi. You can also use the 'gpio readall' command to get an overview of the Raspberry Pi's GPIO layout.
Hi, I would like to get this motor without the encoder, can I get the just the motor + gear assembly?
JaneYu Hi Patrick,
This is a Brushed motor. For brushless motor please check the link below,
JaneYu Thank You for your response but in these specifications i can't find motor Torque Constant and Back emf Constant which are always provided by motor's manufacturer.......
JaneYu Hi, we uploaded its specification, please check. https://github.com/Arduinol... It is written in Chinese. But almost all important information could be found on the product page.
JaneYu
