Hi, the new version is not working, the connection is etablished but i do not receive a data.How work your new appthank youSTARK
JaneYu 2016-10-04 17:22:38 5 Views10 Replies Hi, the new version is not working, the connection is etablished but i do not receive a data.
thank you
STARK
What if you just use the Bluetooth of your phone to see if the CurieNano could be detected and connected.
JaneYu I'm having an error while compiling the code. I'm using your wiki docs, trying to do the first initial test but I'm getting a" 'Goble' was not declared in this scope." not sure if Arduino IDE is recognizing some of the code as an actual language. please help. cheers
JaneYu Hi, it could be the problem with the IDE version, please try 1.0.* IDE.
Hi there, i'm trying to connect the GoBLE app on my iPhone with my HM-10 bluetooth module. I can connect with the module when using LightBlue but unable to pair when using the GoBLE app.
Can you shed any light on this issue? Is the HM-10 not compatable for some reason?
Thanks in advance.
JaneYu Hello, Goble is only support for the DFRobot BLE device. Their profile are not compatible.
First off, thanks DFRobot for making cool products.
Program the HM:
AT+BAUD4
AT+UUID0xDFB0
AT+CHAR0xDFB1
Power cycle HM-10.
Then adjust the example code to display on the appropriate Serial for your LB/arduino of choice.
Can you add the ability to choose a specific device back in?
I have a finished project where I choose an individual device from a bunch of active bluetooth devices. Having to get close to each one to connect ruins the project.
JaneYu
