Hello,can we use this with the beetle?Thanks
userHead JaneYu 2016-10-17 18:36:28 12 Views5 Replies
2022-12-27 06:06:48
How much does the module weigh?
Will vibrations affect its capabilities?
2022-06-04 01:06:08
How can I conenct this with 3V power supply? When I simply connect it, the white LED doesn't light up. It does light up connected to 5V, so I know it's working
2019-01-02 21:05:16
We can connect two same mpu6050 to arduino by using AD0 pin, but this breakout doesn't have it. Then how can we connect two sensors to arduino. Kindly waiting for the response.
This sensor communicates with arduino through I2C, and only have one slave address, so you will need a I2C multiplexer to connect two or more same sensor to arduino. Check out DFR0576: https://www.dfrobot.com/pro....
2019-01-03 11:41:56
2017-11-21 15:26:10
I can't get data from MPU6050 sensor with Romeo for Intel Edison board? Anyone can explain it for me?
