Hi. Can you share the MIPI 30 pinout datasheet of this lcd? I'm trying to use this screen to another project and need to reconfigure the pinout.
JaneYu Do you mean this as the expanded screen? But this is only compatible with LP...
JaneYu Hi, when will the display back on stock?
JaneYu Hey Roger,
Thanks for the interest. Due to high demand, the display will be available in early September. If you have any other questions, feel free to reach out to us at [email protected] or ask another question here!
So i'm Not understanding above it says you have ISP ribon type ports for the display you sell a 7" inch and 10" and on both of those pages of screens under them in the specs it says they dont work with aalpha latte panda so im i readding it right you sell a really high end Latte panda For having lots of Power in you all in one project but the LCD screens you cary only fit the slow model and not the alpha ? so what are the display ribbon cable ports on the alpha for ?
JaneYu For now, LattePanda Alpha uses screen through HDMI, the cable ports is for the screen we plan to release later.
Yes, we have enough in stock, you can contact [email protected] for mass purchase, and we will give you a discount for them.
JaneYu will this screen work with the new delta and alpha latte panda series
JaneYu I don’t think so, the display port of alpha & delta are different with first generation LattePanda board.
Today is June 5, 2018. Is this IPS Display IN STOCK now ? I'm
trying to make a purchase and want to buy everything in one order.
JaneYu Is there a datasheet for the display? I'd like to know detailed measurements of the frame. Some places say 2mm, but it's clearly not even all the way round.
JaneYu Do you think an "Asus Tinker Board" can run this 7-inch screen
like a Raspberry screen.
Thanks you for your complaints
JaneYu Will this display work with Ubuntu Linux - are the Linux drivers available, or only Win 10?
JaneYu If the connector works, then Ubuntu Linux is compatible with this display.
No, not compatible. We will release new and better display screen(together with touch panel) later.
JaneYu The Sales | DFRobot member helped me when I was in trouble about 7 inch Display. I am very grateful. I support FDRobot.
JaneYu What is it communication interface?
JaneYu The communication interface is MIPI, you can find out the pin map from our website http://www.lattepanda.com/d... https://uploads.disquscdn.c...
when you use the display and the HDMI display at the same time, it's just like the extended screen on the computer, the usage is the same as how to use in a computer
JaneYu DF Robot when can we get an answer to Robert Ng's question from 2 months ago?
If I use this 7" display and another HDMI display at the same time, do
they appear as two separate monitors in Windows? Can I display
different content on both displays?
JaneYu I ordered this item along with a few others last November. The items were only partially shipped as the display was not sent. It was stated that the display was out of stock and that it will be shipped as soon as it is available again. May i please know when i can expect this product to be shipped.
JaneYu Hi,
Could you provide the order number? You can email: [email protected] for more information
Do you think you could suggest 4:3 aspect ratio 5.6 inch 640x480 screens to the Latte Panda team?
I've been wanting to use something like this:
http://www.ebay.com/itm/252...
for a project with the Panda, but this being 50 pin while the Panda only having a custom 30 pin connector (according to their twitter) put a damper on my plans (they told me I could theoretically wire an adapter, but I'm not experienced enough to do that).
JaneYu
