What is output shaft dimension? Or is there maybe a possibility to get cad model?
JaneYu 2016-11-23 02:33:39 16 Views4 Replies What is output shaft dimension? Or is there maybe a possibility to get cad model?
2024-04-22 09:04:17
JaneYu
How do you recommend mounting the L shaped motors? I only see the two holes towards the end, but they seem quite small and fragile.
JaneYu JaneYu
wrote:
2024-04-22 14:43:14 1 Replies
The two holes at the end are to hold the motor ** in place, perhaps you could 3D print a motor mount for the construction of the motor.
2016-11-25 14:18:51
JaneYu
Hi, you can refer to the other 3D model. their shaft size are same http://image.dfrobot.com/im...
JaneYu
