I'm from Quebec, Canada. Is it possible to Delivery in Montréal ? I would like to buy : LattePanda (2G/32GB/with Win10 License)Are you sure it's gonna be avaible at the end of janu...
JaneYu 2016-11-23 09:36:01 10 Views45 Replies I'm from Quebec, Canada. Is it possible to Delivery in Montréal ? I would like to buy : LattePanda (2G/32GB/with Win10 License)
Are you sure it's gonna be avaible at the end of january 2017 ? Please answer me as soon as possible.
LattePanda V1 does not come with 3.5mm speakers. But it is compatible with any 3.5mm interface speaker.
JaneYu My activated board didn't come with a written activation key.
How do I find the key to change to the Enterprise OS?
http://docs.lattepanda.com/...
JaneYu Hope it can help you.
http://www.lattepanda.com/f...
Is only Windows supported on this device? Can I install Linux instead?
JaneYu It should be OK, you can refence this link: http://docs.lattepanda.com/...
Hello Dear!
I hope you are great.
I am from Brazil, and we need to buy this LattePanda 2/32gb with Windows 10 for our company, probably periodicaly more than 25 piaces . What is the best channel of distribution? Do you have some partner here in Brazil? Or some e-mail contact?
Sincerely yours,
Joel Alves Lima
www.linkc.com.br
JaneYu Please email to our sales team and we will contact [email protected]
Hello
Can I boot LattePanda with 5v on the cn2 pin?
JaneYu Pls update the boot by this link: https://www.lattepanda.com/...
Or you have other questions, pls contact [email protected]
sorry, processing performance is not up to, let's take a look at thishttps://www.dfrobot.com...
JaneYu hi, i need to connect 2 usb smart card readers directly on the board without using the USB ports, is that possible?
JaneYu We would suggest an 8GB RAM to be safe, and a minimum of 4GB. It depends on the application you use, but generally the bigger RAM the better. We have another LattePanda with 4GB, and our new LattePanda Alpha has 8GB. Check them out. :)
JaneYu "You need to activate Windows before you can personalize your PC".
I'm unsure how to activate this device. I came across a LattePanda forum link[0] for activation but seems I didn't get an activation card with my details on there.
Is there any way to activate this PC? I have purchased the licensed version.
Sincerely,
Tanil
JaneYu Please send your order ID and details of the issue to [email protected], thanks!
LP is mini PC which you need to connect a screen to display the operation system, and it also combine a Leonardo on it, just like an Arduino connected to PC, then you can use different PWM on Leonardo. If you want to use different atmel controller, you can totally use it as a PC to realize it.
JaneYu Would that just be a micro sd card, and what is the maximum storage I can add. Is this the only way to add storage?
JaneYu Is there any way to add storage to the LP, like add a pc hard drive or ssd since it only comes with 32gb of storage.
JaneYu DC, you can take a look of the recommended adapter here http://docs.lattepanda.com/...
JaneYu Hi, the lattepanda that they sent to me does not start the operating system and it goes away alone? what is the problem and how will they solve it? It was very expensive for it to receive faulty. I hope solutions
JaneYu Do you mean it can't start? what the screen showed when you turned it on?
Exist any way to turnOn the Lattepanda witout pressing the porwer button?, I just want connect the microUSB and automatic start the OS.
JaneYu You can set in BIOS, turn on LP and keep press ESC, under boot, there is a choice that choose to turn on LP when the power is connected.
Hi...
This is the test about :
"I guess it would caused by the connected of the positive and negative electrode of the motherboard power."
https://www.youtube.com/wat...
A Greeting
Fernando
JaneYu Have you shorted the board? or what did you do before this board broken
Hello
Yesterday I connected my lattepanda and it does not work.
The blue arduino led lights up but does nothing else.
I bought it 6 months ago and I want to know the status of the warranty.
thank you and what should I do for your repair.
a greeting
Fernando
JaneYu
