hello....we just realise that on our Order ID: 89145, we were bought Real Time Clock Module (DS1307) V1.1 28 pcs, but the one that coming to us was Real Time Clock Module (DS1307) ...
JaneYu 2017-05-24 18:30:42 13 Views8 Replies hello....we just realise that on our Order ID: 89145, we were bought Real Time Clock Module (DS1307) V1.1 28 pcs, but the one that coming to us was Real Time Clock Module (DS1307) (SKU:DFR0151), so, base on that can we and could we ask you to change / replace the RTC that you had wrong to sent us. ? Please advise and comment asap, thanks-juliet
https://www.dfrobot.com/ind...
Sorry it could not receive the External Signal.
The SQ pin is just to output the Square Wave in different frequency.
JaneYu From Specification section: "4KB ROM of EEPROM".
Does it mean this module additionally has memory available for user purposes to write/read any required data ?
JaneYu Yes, you could read/write data to the EEPROM.
Please refer to our Github.
We have written the API function of EEPROM.
Thanks for the reply, but would there be any difference in wiring? To my understanding, this module only works in 5v but the raspberry pi pin is working under 3.3v.
JaneYu Dear Robert
What is the diffrent between this (RTC V1.1) and https://www.dfrobot.com/wik...
JaneYu They're two versions, compare to version 1.0, version 1.1 has EEPROM, so it has more room to save data and it can change the I2C address
You mean you want to add a RTC module on the lattepanda? Actually, lattepanda comes within RTC module on the board. Just add a battery.
JaneYu Hi, DS pin is prepared for the DS18B20 temperature sensor, please ignore it.
JaneYu
