Hi there, can you tell me if I can use this buck converter to power 6 x 6v DC motors (output) using 1 x 8.4v LIPO (input)? Thanks.
userHead JaneYu 2016-12-06 11:40:35 15 Views19 Replies
2022-02-28 19:46:53
Hi, what does voltage calibration mode look like? When i hold for three seconds the display goes blank. Is this normal ?
2021-09-30 18:18:18
Hi Lachen,
Please contact us at [email protected] with a picture of the output and the procedures you are following.
2020-11-13 20:23:32
I need an output voltage of 4V and less than 1A will this product work?
Yes, I use it to drop 12v to 2.7 for my thermostat.
2021-07-04 04:23:42
2020-08-14 15:29:31
Not sure on heat sink. Could an appropriate one be an add-on?
2020-08-14 15:27:24
Can these be put in parallel to get higher wattage? Say 3 x 20 for 60 watts?
2020-08-06 23:54:36
I have two units. Both of them behave the same way.
I use input voltage around 5V. Output is ~0.2V lower.
When I turn pot, output does not change. (verified by external meter)
Have not calibrated internal meter.
2020-07-22 03:24:28
Hi, if I set the output to e.g. 12 V, but the input varies between 13.6 and 14.4 (depending on battery charge level), will the output remain at constant 12 V, irrespective of fluctuation at input (13.6 V to 14.4 V)?
2020-07-01 01:46:23
Hi, I want to calibrate the output to 7.4 V but when I enter the calibration modus I can only select values between -5 and 5 in hole steps by pressing the button once. I think I can change the output voltage by calibrating the screw on the “blue thing” above the display. How can I change the voltage to my own desires?
2020-06-16 20:36:37
What is operating temperature range for the buck converter module??
We have one setup with buck module installed in it will go to thermal chamber max. 50C.
2020-02-16 00:26:11
Do you have any STL files for a box that this board would fit?
2019-10-17 18:21:11
hi,can you provide dimensions and all positions of mounting holes
hi,Nagasai Thokala
Mounting hole distance: 6.1*3.1 (length * width)
Peripheral size: 6.6*3.6*1.2cm (length * width * height)
2019-10-21 16:50:45
2019-10-10 11:16:44
The mounting holes are 3mm diameter (M3), and in and out sizes are actually adjustable sizes via a screw.
2018-12-18 18:34:58
Hi, How to adjust to output voltage ? What do the calibration do ? Thanks
2018-08-07 10:43:39
Hi! I wish to use this, but I think I have to mount it on another board. Where do you I find mounting details of this as I don't see it on the datasheet. I need to know the lenghts spaces, etc of the mounting holes.
2018-05-15 21:51:50
how many days are the delay of delivery to have this product in this address : ZA route de Tours 37320 Saint Branchs, France? thanks
https://www.dfrobot.com/ind... Here is the shipping information.
2018-05-21 19:26:15
2018-04-24 14:42:12
Hi, i want to use this buck converter to have 15.4 W as output, my question is that if i should have any current as input to do the convertion? beacuse in input we have only 24V.
