Oh how I wish this board supported 3.7 Lithium Ion/Polymer battery power and have a charger for the battery and had an SD Card storage slot. If it did, I could buy hundreds if not...
userHead JaneYu 2016-12-14 13:57:51 14 Views6 Replies
Oh how I wish this board supported 3.7 Lithium Ion/Polymer battery power and have a charger for the battery and had an SD Card storage slot. If it did, I could buy hundreds if not thousands of them at 2x the price... :-(
2019-01-17 18:13:15
Can I know if you have install the Arduino environment successfully? Or you plan to develop Edison directly?
2018-10-20 21:53:34
Hello, I am trying to drive a servo using the PWM3 output and external power. Unfortunately it results in severe jitter. Do you have suggestions or a workaround for this problem?
Can you upload the sample code successfully?
2018-11-02 18:20:27
2017-06-27 20:17:48
I am able to get this I2C OLED display, https://www.dfrobot.com/pro..., working just fine with this expansion shield. However, when using the Intel Edison Kit for Arduino, https://www.arduino.cc/en/A..., I cannot get the same I2C OLED display to work. What is the difference between the I2C pins on these boards?
Is the Blink example works for your shield with Edison?
2017-06-28 12:01:47
2017-05-06 18:15:55
Has anybody tried to run vanilla kernel on it and see if it works reliably?
