Hello. Could you provide a mechanical drawing of the metal round horn that is included with this servo? I need the full dimensions (diameter and thickness for the horn and type of ...
JaneYu 2017-01-08 11:25:12 12 Views10 Replies Hello. Could you provide a mechanical drawing of the metal round horn that is included with this servo? I need the full dimensions (diameter and thickness for the horn and type of screw threads) to determine if it is suitable for my application. It is the same as this item: https://www.dfrobot.com/ind... Thanks
i want to buy the DSS-M15S with analog feedback but i also need the Metal round servo horn from this version. Where can i get this?
JaneYu I meant the metal round servo horn, not the mechanical drawing of the servo, all I need is its hub pattern.
JaneYu How can I reduce the max torque? (Dont want to change the servo because of dimensions). Currently it so strong, it is breaking my handles sometimes.
JaneYu Does the servo move 3 degrees for every degree the stick on the transmitter is moved?
JaneYu Hi, will this servo rotate 270 degrees if the transmitter stick is moved 90 degrees?
JaneYu
