Dear Sir/Madam,I bought this shield last month. I followed the instructions to set up the kit. However, it does not work. I used an external power supply (AC-DC) with 9V, 2A rating...
userHead JaneYu 2017-09-14 04:05:16 6 Views3 Replies
Dear Sir/Madam,
I bought this shield last month. I followed the instructions to set up the kit. However, it does not work. I used an external power supply (AC-DC) with 9V, 2A rating to power up the kit. I connected the power supply to Arduino, the power lid is ON with red colour, the lid state is OFF and the network lid is also in OFF state. In addition, I programmed the Arduino, however, the shield is not working. I don’t know what is the problem exactly. I would be grateful if you can guid me to sort this problem. Thank you in advanced.
Look forward to hearing from you.
Best wishes
MCS Hussain alaa
2018-02-27 17:27:46
Hi, Yes, this tracker works in Bangladesh, but it is not continued, it is compatible with Arduino and you can change the code, add other sensors on the shield.
2017-02-09 11:58:46
The baud rate? is that right?
2017-01-11 03:39:43
The power supply is given through 7V, 2A battery and the uart switch was positioned in the middle. The shield was even tested outside..
