Thanks for the Kit! i am going to order a few more of these and make them a bit more complex using more BEAM principles. I like the addins to make it personal. Keep up the work!
JaneYu 2017-01-14 03:16:14 6 Views5 Replies Thanks for the Kit! i am going to order a few more of these and make them a bit more complex using more BEAM principles. I like the addins to make it personal. Keep up the work!
Hello DF! can someone give me some pointers on how to get the robot to move forward? Right now it spins either left or right. It does track the light very well, and only took about ten minutes to assemble. I love the easy instructions,. Any ideas would be appreciated thanks!
JaneYu Hi John. How about try to reverse the motor line? It is reported that this will help it move forward.
And from its product manager, it may depend on the position of the motor.
She said It needs some patient tries. Hope you good Luck :)
Have a nice day!
i will! I love that you have taken the componeents for ktis i have already made and make them available easy to use for kids! i make these same robots, but without PCB...
Can you make a kit with Solar power? Maybe using the Miller Solar engine? Then they wouldnt need a battery, and would chase for more energy! it wouldnt take a lot to convert the battery into two little solar wings, like this ... http://www.ohgizmo.com/wp-c...
JaneYu , plus , adding those two guitar wires on the front, disconnect the battery on the other side, making it obstacle avoiding. No prgramming required!
