The Touch Kit library on this page doesn't work for me. I get the following compile error: 'CapaTouch' was not declared in this scope. I already had a library called 'MPR121' so I ...
JaneYu 2017-01-15 04:10:16 7 Views4 Replies The Touch Kit library on this page doesn't work for me. I get the following compile error: 'CapaTouch' was not declared in this scope. I already had a library called 'MPR121' so I had to rename the folder and re-zip it as 'dfrobot_MPR121' in order to add to my library manager. This shouldn't make a difference should it? Please advise.
2019-12-11 10:37:48
JaneYu
Hi, what is the diameter of the holes on these boards? I'm not certain after looking at the dimensions.
JaneYu 2017-01-18 19:37:53
JaneYu
How about rename your old "MPR121" library to another one, and use ours?
I've tested it and there are no error when compiling.
BTW: I'm using 1.6.13
JaneYu
