hi, have you got datasheet for the switch.. I want to get the exact measurements
JaneYu 2017-02-03 03:19:47 7 Views5 Replies hi, have you got datasheet for the switch.. I want to get the exact measurements
2018-02-13 13:56:01
JaneYu
Hello I am designing a module and I want to use this component. Do you have a cad file. I am using Inventor.
Thank you.
JaneYu 2017-06-11 21:53:24
JaneYu
So when will the new model come out?
JaneYu JaneYu
wrote:
2017-06-12 17:51:07 1 Replies
A new rotary switch module will come out at the end of this month, but it's not based on analog signal
2017-03-22 15:04:38
JaneYu
The same position value of each switch is different. Please refer to the wiki.
JaneYu JaneYu
wrote:
2017-10-16 19:33:52 1 Replies
The values are not stable. I already need to change them again and every time I power ON the circuit, the values changes and I need to adjust again.
There are some secret to stable the values to stop this constant changes. I already try to put a RC circuito to filter the signal, but steels changing.
