Can you create ScratchX programs to control sensors and actuators connected through the shield?
userHead JaneYu 2017-02-07 16:00:15 6 Views2 Replies
2017-04-18 18:26:52
Hi did you burn a new firmware to ble link successfully? Just refer to the tutorial and following link to update the firmware to usb ble link first, https://www.dfrobot.com/wik...
Once the firmware updated successfully, then try to upload the ble code to 101 later, they will build ble connection automaticlly.
As for the error in the IDE, its a little strange, or change another IDE to try again? Its more like a format problem. Did you open the code directly from our example?
2017-04-11 09:55:19
Hello! I am going through the tutorials, and I am having a difficult time connecting the 101 with the bluetooth dongle. I have included the library and the 101 is transmitting a BT signal (I can see "BLUNO101" when I scan for devices on my phone), but when I have inserted the dongle into my Windows 10 computer, it doesn't connect. Can you help? Thanks!
