Hi I would like to know the Stall Torque of this motor because it's written 45 Kg.com ?
JaneYu 2017-05-03 02:02:05 7 Views11 Replies Hi I would like to know the Stall Torque of this motor because it's written 45 Kg.com ?
Is using jumper wires for the supply voltage enough since the stall current is 7A.
If not, any recommendations?
JaneYu Jumper wires are generally thin and not capable of handling 7A current, please check the wires in this link:
Do I need a motor driver along with Arduino to run this motor or Arduino itself is sufficient?
JaneYu What inductance FIT0105 has? I need this parameter for pwm frequency calculation.
JaneYu Hello,
I would like to purchase a couple of these motors. Are there any torque-velocity curves for this motor? Also, what are the associated motor constants for this motor? Is this motor brushed or brushless?
Any assistance is greatly appreciated.
JaneYu Hi,
There is no torque-velocity curve, the only constants are list in the specification and this is a brushed motor.
Can I easily install these motors on the 2WD turtlekit plateform (ROB0005) ? What kind of wheels is compatible with these motors ?
Thanks !
JaneYu I don't think these motors are fit for ROB0005, but these wheels is compatible for the motors: https://www.dfrobot.com/pro...
