Do you have an outdoor version for this sensor?
userHead JaneYu 2018-07-17 00:55:10 13 Views14 Replies
2023-08-29 23:26:56
Hi, am i able to connect this with a TVOC sensor, preferably CCS811 tvoc sensor? Using it for arduino
2020-06-16 15:45:25
how to solve the problem?
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
libraries\DFRobotHCHOSensor\DFRobotHCHOSensor.cpp.o (symbol from plugin): In function `DFRobotHCHOSensor::DFRobotHCHOSensor(HardwareSerial*)':
(.text+0x0): multiple definition of `DFRobotHCHOSensor::DFRobotHCHOSensor(HardwareSerial*)'
libraries\DFRobotHCHOSensor\DFRobotHCHOSensor - Copy.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `DFRobotHCHOSensor::DFRobotHCHOSensor(SoftwareSerial*)'
(.text+0x0): multiple definition of `DFRobotHCHOSensor::DFRobotHCHOSensor(int, float)'
(.text+0x0): multiple definition of `DFRobotHCHOSensor::checkSum(unsigned char*, unsigned char)'
(.text+0x0): multiple definition of `DFRobotHCHOSensor::available()'
(.text+0x0): multiple definition of `DFRobotHCHOSensor::uartReadPPM()'
(.text+0x0): multiple definition of `DFRobotHCHOSensor::dacReadPPM()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
2020-06-09 13:22:48
What is power consumption of the Formaldehyde (HCHO) Sensor?
2019-09-02 09:56:29
Hey Dipen,
Nice setup. The sensor actually supports a wide range of input voltages, specifically between 3.3~6V. As long as you meet these requirements in your setup, you should be fine!
2019-08-08 08:12:41
It's not compatible with RPi. We only provide libraries for Arduino.
Does it use on Arduino uno R3?????????/
2019-08-14 10:29:22
2019-06-03 16:32:46
What is the recommended installation inside a (plastic) case? Upward, downward or sideway orientation? Distance to case? Airflow?
2019-02-13 14:08:50
Yes, this is a electrochemical sensor, once it is exposed in air, the sensor start degrading.
2019-01-28 10:41:59
Are there any guides on how to setup this sensor on a raspberry Pi? The Product Wiki says Raspberry Pi is compatible but has no further documentation or sample code.
There are two modes to use HCHO sensor UART and DAC, it is the same as communicate through UART in Raspberry pi, you can also add an ADC like control an analog sensor.
2019-01-28 16:04:14
2018-07-17 10:16:48
Why do you want to measure Formaldehyde outdoors? Normally we use it to measure Formaldehyde in the room.
2018-03-20 16:51:36
This sensor is not open for calibration now.
2017-05-15 13:11:23
Hello, this sensor just detect HCHO in air. According to your request, do you need a VOC gas sensor?
