Do you have a waterproof version of this one ? Looks good otherwise.
userHead JaneYu 2017-08-09 11:17:27 11 Views6 Replies
2022-08-05 14:10:52
Hi, The module can be used in series in Raspberry PI
2022-03-09 16:21:08
Please contact our technical support mailbox [email protected] and elaborate on your question, thank you.
2018-03-20 17:12:12
I NEED Distance Resolution: 1MM AND DIAMETR not more than 1 inch. Or I need a command to translate URM07 - UART into 1mm. I understand that this will not be accurate, but I need in mm
2018-03-20 14:08:11
i need URM07 I2C Ultrasonic Sensor (SKU:SEN0166)
2017-08-09 12:07:29
This is a water-proof ultrasonic sensor. Where do you plan to put the sensor in, Is it a moist place?
Yes in a water tank, not intended to be underwater but in a very humid environment.
2017-08-09 12:16:10
