Hi !Do you have the curves of current, torque and efficiency of the motor?regards
JaneYu 2018-04-04 11:25:42 11 Views2 Replies Hi !
regards
2017-08-11 21:43:58
JaneYu
But you have to highlight on the drawing that does not include the encoder, it create a lot of problem when parts already fabricate and cannot assemble, especially when the motor is mounted back to back, its 40mm different ! how to mount?? Now I facing this problem right now.
JaneYu JaneYu
wrote:
2017-08-12 21:50:37 1 Replies
Admin
Please update your pdf drawing of the datasheet before other get into a mess like me !!! If you don't have the drawing, attached below is drawing with the actual dimension I have measure from the motor I have. If you need a 3D part, I can email to you.
