Hi, can the sensor be covered by 3mm wood and still be effective?
JaneYu 2017-09-07 17:16:56 14 Views14 Replies Hi, can the sensor be covered by 3mm wood and still be effective?
Hi @tademiha, I have the same problem with the sensor. Did you fix it?
If so, what did you do? What was the solution?
Thank you in advance.
JaneYu Hi,
Sorry for the inconveniences. The link in the English wiki indeed isn't working. We will fix it asap. In the mean time, if you are in hurry, you could use this Chinese WIKI (you can use google chrome to auto translate).
Hope it helps for the time being. Thanks for understanding.
JaneYu This is the information we can provide for your reference.
http://www.dfrobot.com.cn/i...
JaneYu No! This is the information Microchip can provide to all users.
I was specific when I asked about the parametrization firmware (a .enz file genetrated when you calibrate the IC parameters according to your electrode desing).
Microchip also provide various parametrization file according Microchip's reference desing, wich differ from yours electrode desing.
But your desingns do not folow the default reference, thats the why I am asking about your parametrization firmware so I can use this sensor on my project.
Simple like that. I do not understand all that dificulty to provide correct information.
Any way ... thank you.
The code of the video is just the servo move an angle after detecting the gesture movement. You can refer to the wiki code and the control of Servo.
JaneYu In my project i would like to identify the linear movements of the hand of a visitor, say following the axis of the sensor (e.g. from "Down/right" to "Left/Up" or maybe easier from "Down" to "Up" or "Right" to "Left"), moreover i'd like to know the speed of the hand, but this is optional. What is possible with the SEN0202? I didn't find the full doc about the Arduino library..
My purpose is to convert the movement into a new position of servo's controlling two laser showing lines on the ceiling of a church; the hand position would be delayed with a simple lag filter (to avoid the priest getting crazy ;-)) )
Thank you for your help
Richard
JaneYu The library is here: https://github.com/DFRobot/... the sensor can only detect four directions and CCW/CW, and the movement of the hand should not be too fast.
