There is no touch for this lovely screen?
userHead JaneYu 2017-11-28 02:12:11 10 Views17 Replies
2023-07-25 09:26:56
can it use with lattepanda sigma?
2023-02-02 17:43:03
Morning, This is touchscreen ? sensitive or capacitive ? Thank you
2022-09-07 15:03:24
Hi, i have this display and want to use it with Latte Panda 3 Delta, i already know the pinout for this display and latte panda screen connector are both different but is there any method to convert this display into an HDMI monitor?
2022-01-04 04:56:39
Hi, I would like to use this display using HDMI. Is there an hdmi adapter board for this display, similar to https://www.dfrobot.com/pro... that would allow me to do that?
2021-01-13 04:58:44
Is this compatible with the S70CR200-CC34F LattePanda V1.2 board? I'm getting a black screen on the display and am unable to update the BIOS with the provided BIOS files (boots directly into Win10).
2020-09-21 09:15:34
Hi Dans,
Here's one HDMI 1200x1920 screen for LattePanda Alpha/Delta
And here's a new 4k IPS touch display
If you have any other questions, let us know.
2019-11-25 15:49:12
Before buying this, I'm worried that this high resolution won't slow down my lattepanda.
2019-09-10 12:36:50
I understand that the screen does not support Alpha series, so I ask if there is a driver board for this screen.
2019-04-03 19:33:22
Touch panel overlay for this?
2019-01-09 17:18:09
do you have plans to release a 7 inch display?
We have a 7 inch HDMI touch screen compatible with LP. Chech out: https://www.dfrobot.com/pro....
2019-01-11 11:24:33
2018-12-06 06:45:33
We all need to know about the capacitive touch Panel overlay for this display.
2018-10-21 11:35:58
Any news about the capacitive touch Panel overlay for this display?
2018-10-10 11:48:21
Can I use this as a LattePanda Alpha 864 display?
2018-02-08 20:39:44
May I know when we can expect the touch screen for this display?
2018-01-23 11:04:26
No, this display is still fit previous version LP, we will release a specific display for LP Alpha.
2018-01-22 14:04:24
No, the pinout is different, it's not compatible.
