Just say hello.i am beginner of Adruino.Regard's
JaneYu 2018-01-06 14:23:13 12 Views13 Replies Just say hello.
Regard's
Thanks for the response. But I don't see the plastic borders for the box internal space. Just to clarify, I'm referring to these transparent plastic panels for the box to use the box as an organizer for parts.
Here's what it looks like in the "Gravity: Arduino Zero to Hero Kit". As I understand it, there are no such transparent plastic panels in the "DFRobot Beginner Kit for Arduino (Best Starter Kit)" kit to divide the space of the box?
JaneYu Sorry for the late reply. Yes, this kit does not have transparent plastic panels.
Does this package include dividers of the box into organizer cells as in the "Gravity: Arduino Zero to Hero Kit"?
JaneYu Hi, This is the abbreviation for code. I suggest you can look at the code format。
JaneYu Hello. Has the kit a RGB LED? There isn't in the shipping list, but it's in the Projects 5 and 12. Thanks.
JaneYu Hi,
It has the RGB LED. It's contained in 5mm LED pack.
поправьте пожалуйста коды в описаниях к карточкам в этом наборе, множество ошибок, вот ссылка где есть исправленные https://github.com/bluino/B...
JaneYu My question:
I already bought Beginner Kit for Arduino, but i found difficulties for install the driver, because at tutorial is not same (tutorial version Arduino 1.0.5 but available for Arduino 1.8.5)
How about it, please help.
Thank you
JaneYu Hi,
It is OK to use Arduino 1.8.5, you can follow the steps shown on the tutorial, what is the specific problem it is? You can't find the driver?
