Is this out of stock?when will you refill it
userHead JaneYu 2018-06-01 14:58:27 11 Views7 Replies
2020-11-02 09:17:35
Hi Lorenzato,
Yes, you can, usually a good approach to do it is by multiplexing single UART. There are other several methods for it. I think you'll find the post in his forum useful. This explains several methods pretty well.
https://forum.allaboutcircu...
2019-08-24 00:02:55
Is this kind of devices operates in the dark or very low light, like into a mine ?
Hey Julien,
Great question. The Laser Rangefinder only has an upper bound of 100kLux of ambient light and therefore will work fine in low light scenarios.
2019-08-26 09:45:43
2019-08-20 10:35:33
Hi!
this sensor could detect a car at 250 k / h ???
2018-10-25 07:13:52
TIENE UN SOFTWARE PARA SU CONTROL?, LO NECESITO PARA MEDIR LOS METROS DE UNA TUBERIA.
Hi, we only have an Arduino tutorial about how to use the sensor, you can use the Arduino code to measure the length of the pipe.
2018-10-25 08:36:51
2018-01-18 11:00:28
The water surface may have affection to the laser, which may make the measurement unreliable.
