I would like to load the newest firmware onto this board but the zip file is empty https://github.com/DFRobot/.... Where can I download the newest firmware. Also I have used blueto...
JaneYu 2018-01-23 08:43:01 10 Views4 Replies I would like to load the newest firmware onto this board but the zip file is empty https://github.com/DFRobot/.... Where can I download the newest firmware. Also I have used bluetooth HID successfully on other bluno boards and it works well. I am following these instructions https://www.dfrobot.com/for... but I can't get it to work on this board can you verify if it works on the M0 bluno board.
Yes, it is a 10 bit ADC.
The software pwm is like analog pins, you can use AnalogWrite on it.
JaneYu Hi,
We found you have left some question about this M0 board, this is a board good for developers to discover the functions it can provide, there is some problem with the compatibility. Could you send us a Email to our tech support Email, we can discuss details about the problem in this board, it will help both of us to develop more about it, Thank you!
JaneYu
