Please post the source for the pogo pins for people who would like to build a custom adapter.
userHead JaneYu 2018-03-31 04:10:48 383 Views1 Replies
2020-11-08 05:18:40
Hi I bought the eClip but my PCB ICSP header holes are too large to fit the pogo pins correctly, they are the header mounting through holes not the test point holes. The supplied pogo pins slide through. The header through holes are 0.1" spacing which are 1.02mm in diameter. Can you recommend a larger size set of pogo pins that will fit these holes correctly?
