I have been working with these things for two days and I still cannot get these radios to work. Has anyone had success and would you be willing to share how you did it? I do have...
userHead JaneYu 2019-10-14 00:46:38 8 Views4 Replies
I have been working with these things for two days and I still cannot get these radios to work. Has anyone had success and would you be willing to share how you did it? I do have the Chinese application for configuring the radios and that does communicate with the module. However, I have not had any success in getting the radios to behave as they are described in the datasheet. They seen to default to the HEX Command mode not the transparent mode described in the datasheet, and I cannot get then to enter the AT Command mode.
2020-12-24 15:46:30
I want to communicate with this module by arduino mega2560, but there is no tutorial or some example. I cannot enter AT command by arduino. help
2018-09-03 17:27:38
Sorry, we don't have schematic or other document about this product, the configuration could be done by a serial tool.
2018-08-31 17:07:45
No, they are different, LoRa can only do point to point communication, LoRa Mesh can make Mesh network.
2018-07-09 16:21:32
You can find a datasheet of this module here: https://github.com/Arduinol...
