Hi, When are you going to re-stock up again and does it support common anode RGB LED Matrix ?
JaneYu 2018-11-19 09:50:19 399 Views1 Replies Hi, When are you going to re-stock up again and does it support common anode RGB LED Matrix ?
2019-09-12 21:55:33
JaneYu
Hey dfrobot, I'm trying to compile code using the rgb_matrix library on esp8266. But when compiling an error appears https://pastebin.com/WYBcUyT5
How can i fix this? Please, help.
JaneYu
