Hi folks,I have a "Rover 5 Tank Chassis (4 motors with 4 Encoders) / SKU:ROB0055-4M4E" and a "Romeo for Intel® Edison Controller (With Intel® Edison) SKU:DFR0350" to drive it...Two...
JaneYu 2018-11-20 20:40:34 397 Views1 Replies Hi folks,
Two questions :)
a) Where do i connect the 'quadrature encoder output' wires from the Rover to the Edison Controller?
I.e. which pins on controller for all four encoders?
(The four wires from encoder are: RED is +5V for the encoder, BLACK is 0V (ground), WHITE is signal A, YELLOW is signal B.
Manual is NOT clear on this..
b). Could you please attach / paste some arduino code so that i can adjust setting for encoders.
Much appreciated,
Michael.
______
Hi Michael,
You can connect the signal A or B pin of the encoder to any digital pin of the controller. You can refer to the use of the encoder PID click control code.
JaneYu
