Hey there, how's the waterproofing on this module if it's supposed to be left outside 24/7? I guess the USB outlet itself isn't proof, but if I cover the whole converter part in wa...
userHead JaneYu 2019-03-10 23:08:08 25 Views6 Replies
Hey there, how's the waterproofing on this module if it's supposed to be left outside 24/7? I guess the USB outlet itself isn't proof, but if I cover the whole converter part in waterproof epoxy or so, will the solar module itself be OK with rain?
2024-02-10 11:54:59
what's under the USB casing? Is it able to be opened to solder points into it? or will i destroy it trying?
2023-03-08 00:19:08
Is it possible for us to change the cable? We plan to (hopefully) use this to charge up 1 Li-ion battery, or 2 L-ion in parallel , by connecting 1 or 2 TP4056 boards.
I see the below comments that you mention it cant be used in the rain. Is this because of the connector only?
Many Thanks
Scott
2023-03-07 23:05:53
Is it possible for us to change the cable? We plan to (hopefully) use this to charge up 1 Li-ion battery, or 2 L-ion in parallel , by connecting 1 or 2 TP4056 boards. So we will feed the cable to our small enclosure. And can we use it outdoors?
Many Thanks
Scott
2020-10-05 23:44:19
I would also like to know if this panel is water resistant.
Hi Jdmedinat,
Sorry, it's not water-resistant. Follow the link below for water-resistant monocrystalline solar panel
2020-10-09 13:50:31
2018-11-19 16:52:02
Yes, it suitable for Solar Power Manager 5V.
