guys im testing the kit on makecode.1 - Obloq module its not longer available on the extensions search.2 - The pxt github for obloq you have 2 versions. ver 1 and and older. it lo...
userHead JaneYu 2019-02-14 02:29:17 13 Views6 Replies
2 - The pxt github for obloq you have 2 versions. ver 1 and and older. it looks like the older one its not compatible with v1 board.
3 - And a BIG ISSUE it needs to be updated on the obloq makecode is that you cant sent numbers, you can only send string to dfrobot platform. as an example if you want to sent the value of lightsensor you cant. and i did not find a way to convert a int or floar to string.
4 - add more iot platfroms like Thinger.io https://io.adafruit.com/ IFTTT https://thingsboard.io/ etc
2020-11-06 16:18:30
Hi Willie,
Please try plugging the makecode github extension by searching it manually with the following link and let us if that works:
https://github.com/DFRobot/...
Already done that and it works, thanks.
2020-11-06 19:35:30
2020-01-08 14:23:29
Sorry, I confused two different kits I have. I do not use the DFRobot Iot kit as I could not get it to work. I bough the Elecfreak IoT kit and use that one now.
Could you show some details when you work with the production. maybe you could see the DOCUMENTS.
2020-01-09 10:17:35
2020-01-06 08:27:49
They emailed me a reset file I uploaded to the microbit.
There is a link that I hope could help you.
2020-01-06 09:56:19
