Thinking about installing these on the drive motors on a manufacturing line to determine if bearings are bad or motor brushes are wearing. basically I would set up a good/warn/emin...
userHead JaneYu 2019-04-12 04:38:25 12 Views7 Replies
Thinking about installing these on the drive motors on a manufacturing line to determine if bearings are bad or motor brushes are wearing. basically I would set up a good/warn/eminent failure value and alert. anyone out there using these in a similar way? and input is appreciated.
2022-12-24 04:09:29
Hi, can I connect this sensor to the Arduino Uno 33 BLE? I need to use it in analog mode to detect machine vibrations and calculate its FFT. Thanks in advance
2022-04-25 16:51:14
I'm going to measure the vibration.
Is it possible to measure from 1 Hz to 10 kHz?
For example, if there is a vibration of 10 kHz frequency, does the sensor output also have a 10 kHz frequency?
You're using an ambiguous expression, and there's an expression in sen0209 that says "the piezo film sensor has a wide dynamic range (0.001Hz~1000MHz), but I can't find the data of film (LDT0-028K right?) used in sen0209. (at Meas-spec.com)
2021-08-19 13:39:00
Is this sensor and module able to detect acoustic emissions in a polymer film? Thanks in advance.
2019-09-25 15:56:59
hi. can this sensor produce negative value if it's bend to the opposite direction?
2019-08-13 14:25:26
No, the operating voltage is 5V.
2019-06-28 09:23:59
How strong is the vibration? I think it is able to detect. You can test and measure first and set a suitable threshold value.
2019-04-12 10:22:12
Have you considered the life span this sensor would have if put it in this environment? Would this motor or bearings damage the film is the vibration is too big?
