excuse me I would like to know if it's possible for you to send me the technical file of DC Motor x2 for the Max:bot DIY Programmable Robot Kit for Kids .
JaneYu 2019-11-04 15:11:10 14 Views6 Replies excuse me I would like to know if it's possible for you to send me the technical file of
I can't get the Microbit to function once plugged into Max:Bot. The Microbit only seems to work when unplugged from the DF Max:bot. I have tried it on all my class set of robots and no luck.
JaneYu Two Questions.
1: What type of LiPo battery is meant to be used (and what is the cut-off voltage)
2: Is there a servo library you provide that allows the wheel servos to operate? The default one only allows servos on P0-P2.
JaneYu As long as your lithium battery can provide the corresponding 5V stable voltage and the interface can be consistent with our interface, it is all right.About the library, I advice you could browse the document that we provide.
Can I Have the SKU of the DC Motors of
JaneYu It works!
I found the reason that the volume knob is not good position. Thank you.
JaneYu
