(not compatible with LattePanda V1.0) why ?
JaneYu 2019-09-16 21:02:15 20 Views21 Replies (not compatible with LattePanda V1.0) why ?
Hi, is there a sunlight readable touch screen you could recommend?
JaneYu We're sorry we don't have any recommendations for sun-resistant touchscreens in our store.
However, generally other HDMI touchscreens can be adapted to LattePanda, so you can check on other stores.
Hello, the tip of the touch cable of the IPS screen in the LattePanda delta model broke. When I look online, there is a sale for the display cable, but there is no sale for the touch cable. How can I install a cable instead of the touch cable? If I buy an FPC 6-pin cable, how can I mount it on the screen or what is the solution? Thank you.
JaneYu We are sorry that this product does not compatible with the LattePanda Sigma.
A screen compatible with the LattePanda Sigma is under development.
JaneYu Can you recommend a display that is compatible with the third-party LattePanda Sigma?
Related products are under development, you can send an email to [email protected] to inquire about the development progress.
JaneYu Do you know why it is not compatible with LattePanda Delta v3? I see from the documentation that both LattePanda Delta and LattePanda 3 Delta have the same pinout diagram for eDP.. So what is the reason?
JaneYu What is the refresh rate of this display?
Does this work with the LattePanda Delta 3?
Thanks!
JaneYu Please check if your device 30pin EDP interface matches it,http://docs.lattepanda.com/...
JaneYu I need a longer FPC Extension Cable and way to extend the touch screen cable. Where can I get the necessary parts?
Jim
JaneYu Are there any good 3d-printed cases for this I can get printed somewhere in metal or something nice?
JaneYu Yes, the latter picture shows the pinout for the touch screen FPC connector. The other question was what is the touch controller IC part number? Thanks.
JaneYu Hi,
The touch screen does not require any external power. The USB type-C provides enough power for both the board and the touch screen. So, we didn't measure the power consumption of the screen.
JaneYu You marked the red on the picture is M3 tape, it's does not affect the screen, can be used.
If you are worried, you can make a shell for it.
JaneYu Hey,
Unfortunately there is a different connection. We do have the following displays available for the V1.0: https://www.dfrobot.com/pro... and https://www.dfrobot.com/pro...
JaneYu
