How can I adjust the range of detected distance?I only need about 10 cm, but it only works at 200cm, I guess...*editI just checked your wiki website and figured it out.It really h...
JaneYu 2019-06-21 16:13:10 21 Views4 Replies How can I adjust the range of detected distance?
*edit
It really helped. thanks!
2023-12-27 10:08:32
JaneYu
This sensor is a PNP sensor and when triggered the signal wire is connected to the supply +.
So as long as you supply >85mA to the sensor, this sensor can trigger an 85mA relay.
JaneYu 2023-12-25 05:16:21
JaneYu
Is this sensor active or passive IR? That is, does it have it's own IR source? I need a sensor for a completely dark environment. How does it do with a dusty environment?
JaneYu 2023-06-15 03:34:46
JaneYu
but it's water resistant right? and does it also detect transparent objects i.e seawater?
will it also work on stm32 boards?
JaneYu
