Do you have any example code for using this with arduino? The tutorial is not very complete
JaneYu 2019-09-05 11:11:08 372 Views1 Replies Do you have any example code for using this with arduino? The tutorial is not very complete
2026-04-13 17:06:30
JaneYu
Hey Mason,
You can check out the datasheet here: https://image.dfrobot.com/im... This sheet gives you a detailed breakdown of how to the communication protocol works.You can simply use arduino serial communication to send the corresponding hex commands and then listen back for its response.
JaneYu
