I think there is an inversion in the technical characteristics of the 210 RPM and the 100 RPM. To be more consistent with the Maximum efficiency point and the maximum power point, ...
userHead JaneYu 2020-01-19 23:27:24 12 Views5 Replies
To be more consistent with the Maximum efficiency point and the maximum power point, this would give :
- FIT0521, 210 RPM : Stall Torque: 6.5 kg·cm and Stall Current: 3A
- FIT0522, 100 RPM : Stall Torque: 10 kg·cm and Stall Current: 3.2A
2024-01-14 04:06:28
can i use this motor with pirate? i need metal gear motor with encoder for pirate please help
I'm sorry to say that this motor is not suitable for use on top of the pirate. Because the size of this motor is too big.
2024-01-15 11:50:51
2021-12-05 23:38:47
Where can I get information on the encoder interface? Like, what is the data format? What is the data timing? How to interpret the data? And so on.
2020-02-22 06:54:46
What is the dimension of the mounting holes? What is the set screw size and how far from the rotating axis?
2020-01-20 18:18:52
Hi, you can't provide voltages over 6V. If the voltage you provide is less than 6V, it will turn slowly until it stops.
