There is no normal DFRobot Wiki for this product? Do you have working arduino UNO code?
userHead JaneYu 2020-05-14 20:14:22 28 Views7 Replies
2023-10-26 04:04:44
I havbe bowght a TF-LUNA lidar and connected to an arduino (nano). Im using the TFLI2C arduino library and the sample code found at https://github.com/budryers.... Using the default I2C address (0x10) the system works well returning distance values. As I want to connect multiple lidar sensors, I'm trying to change the default address from 0x10 to somthing within the range 0x08 - 0x77. However when I use anything other than the default address the lidar is not initilized returning error. Can you help me ?
thank you
2022-07-15 01:11:17
Good afternoon, I'm developing a project with this sensor and to make it easier I would like to use the same connector used in the module, I reviewed the datasheet but I didn't find a part number. Could you tell me what this connector or indicate a similar compatible one. Thank you very much in advance.
2020-06-29 19:41:50
Sorry, this is an agent product, only the instruction manual is provided.
https://github.com/May-DFRo...
2020-06-28 23:28:39
Where is the arduino library? Can i use the library from TFmini-S LiDAR(ToF) Laser Range Sensor?
Sorry, this is an agent product, weprovide the instruction manual.
2020-06-29 19:43:26
2020-05-14 07:56:48
A sonar might be more suitable for your aplication, I expect lidar to not be reliable underwater because of reflection.
