Can these modules be drilled thru? Thinking of panel with slots thru it, backlit so light shows thru and potentiometer shaft thru backlight and panel. Basically the light showing...
JaneYu 2020-08-15 10:06:51 105 Views4 Replies Can these modules be drilled thru? Thinking of panel with slots thru it, backlit so light shows thru and potentiometer shaft thru backlight and panel. Basically the light showing through the panel would become the graduations surrounding the control knob if that makes sense. To do that I’d have to put a hole in the back light module. Thx
2023-06-14 15:31:29
JaneYu
Hi I'd like to use this as an illumination source without the Gravity display unit. Is there any connection/control documentation available for using without the Gravity control board?
JaneYu
RGB LCD Backlight Module FIT0562
