Can it only be controlled with PPM or will a PWM signal from an RC receiver work too? Also, is it suitable for 6s lipos which have a fully charged voltage slightly over 24V?
userHead JaneYu 2020-08-30 19:09:36 109 Views3 Replies
2022-10-26 07:41:50
Hi! would this work with your FIT-0521 motor? https://www.dfrobot.com/pro...
If not, do you have any recommendations for an esc that works with this motor?
2022-10-26 07:42:40
2022-06-29 06:34:10
Please confirm. The voltage spec says 4.8V to 8.4V. Can it actually handle a higher input voltage? (12V, 24V?) what is the maximum input voltage then?
