Here's what you need to know to make this gadget work:Pins:Vcc | Vcc (compatible with 3.3v or 5v power)PWM1 | PWM2 (PWM input for motors 1 and 2)INA1 | INA2 (motors 1 and 2 control...
JaneYu 2020-09-27 22:50:21 33 Views9 Replies Here's what you need to know to make this gadget work:
Pins:
INA1 | INA2 (motors 1 and 2 control logic input A)
INB1 | INB2 (motors 1 and 2 control logic input B)
GND | GND
Run logic:
INAx low, INBx low - motor stopped
INAx low, INBx high - motor forward
INAx high, INBx low - motor reverse
State LED:
Steady light: normal operation; fast flashing; power supply overvoltage, output is off;
slow flashing: power supply undervoltage, output is off; double flashing: drive overheating, output is off;
Sample code:
This sample code is for testing the 2 stepper motors
The rotation velocity can be adjusted by the code switch
Microcontroller: Arduino UNO
int PWM1 = 2;
int INA1 = 3;
int INB1 = 4;
int PWM2 = 5;
int INA2 = 6;
int INB2 = 7;
pinMode(PWM1, OUTPUT);
pinMode(INA1, OUTPUT);
pinMode(INB1, OUTPUT);
pinMode(PWM2, OUTPUT);
pinMode(INA2, OUTPUT);
pinMode(INB2, OUTPUT);
digitalWrite(INA1, LOW);
digitalWrite(INA2, LOW);
digitalWrite(INB1, HIGH);
digitalWrite(INB2, HIGH);
analogWrite(PWM1, 255); //PWM Speed regulation
analogWrite(PWM2, 255); //PWM Speed regulation
delay(1000);
digitalWrite(INB1, HIGH); //Motor 1 forward
digitalWrite(INA2, HIGH);
digitalWrite(INB2, LOW); //Motor 2 reverse
delay(1000);
digitalWrite(INB1, LOW); //Motor 1 stopped
digitalWrite(INB2, LOW); //Motor 2 stopped
delay(1000);
This driver could only accept the 6.5~37V DC.
So if you use the 40V battery, this could damage to the driver.
JaneYu Believe I Have a similar issue.
Our 12V motors respond as if the board is using the PWM pin as on/off, and are only being supplied the voltage from the logic voltage pins.
Our directional controls work, so our pins are correct.
But when pwm pins are set at 0-127, the motors are completely off. At 128-255 they run at 5V if the logic is on a 5V pin on arduino, or 3.3V if on the 3.3V pin.
Not only do they not respond to the pwm signal for speed control, they don’t appear to have access to the actual 12V supply we are giving it at all, but using the voltage on the logic pins?
JaneYu anyone have the pinout of this shield?
JaneYu Pins:
GND | GND
