Not being knowledgeable of certain devices, so I ask. Q: Can I use this to have a USB connection for a thumb drive? With the prices of thumb drives (USB 1.1, 2.0 and 3.0) so low an...
userHead JaneYu 2020-10-10 04:14:02 31 Views4 Replies
Not being knowledgeable of certain devices, so I ask. Q: Can I use this to have a USB connection for a thumb drive? With the prices of thumb drives (USB 1.1, 2.0 and 3.0) so low and in the gigabyte range, will this work in a Raspberry 3B+ and or 4B to add another USB to a custom case? How large can I go with a thumb drive? etc. any additional information would be welcomed.
2022-04-22 04:52:31
If it has a boot loader on it, then yes. If not, you will need an AVR programmer or an Arduino.
2021-12-02 16:02:50
Is it 2.54mm between the pins?
Where can I find the dimensions of the board? Do you have a gerber file or similar to import to Kicad?
The pin spacing is default 2.54mm
2022-02-24 14:28:19
2020-10-13 16:05:56
You can use it to have a USB connection for a thumb device with Raspberry Pi 3B+ or 4B to add another USB to a custom case but you will need a female USB port to connect it.
